Ir para o conteúdo principal
Removing screen from front bezel non-destructively
Hello,
I'm looking for a way to remove the screen from the bezel of an FZ-G1, I don't actually have the whole device, I just have the front bezel which has the webcam, screen, and front navigation buttons on it. I'm planning on using the display for a project as it has a wacom digitizer and a capacitive touch screen.
Would anyone happen to know of a way to separate the screen from the display without destroying it?
This might not be obvious from the image I posted, but the front surface is not flat as it is on modern devices, there is a bezel and the screen is visible through a cutout in the bezel.
Not sure if it helps but the FZ-G1 has an IP65 rating, so how ever they chose to bond the screen to the bezel must be pretty strong/durable.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
the common way is to heat it with a blow dryer. The tape softens and allows removal.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
coloneil será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 437
