Ir para o conteúdo principal
The V2 Controller comes in different Generations. You’re looking at Generation 4.
10 Perguntas Visualizar todos
Button inputs mixing and matching
I was playing an online game and got so angry that I threw my favourite controller, 5 years old, on the floor full force. I regret it terribly.
I've opened her up many times to change worn out rubber padding. I opened her up again, saw nothing wrong except a broken metal weight on the lower left. Put her together. I use her on PC, so i checked the inputs and they were fine on windows. I check them in game and button inputs are mixing, I press SQUARE and the results with be SQUARE TRIANGE. Or I press R1 and Ill get R1, CIRCLE and CROSS output results. I suspect the green motherboard inside is faulty or needs a replacement? What do think?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
A broken metal part might have caused colateral damage to the PCB that would require careful inspection with a glass to find.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Athi Musoke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 35
