Ir para o conteúdo principal
At the 2004 North American International Auto Show, Nissan unveiled a completely redesigned Pathfinder for the 2005 model year.
14 Perguntas Visualizar todos
How can I fix my car cruise control?
My car cruise control doesn't work properly. Sometimes cannot be activated to maintain a specific speed.
Is it possible to repair it by myself?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
hello, generally you can repair it, the main issues with cruise control are the pedals sensors, in normal operation when you press the brake pedal or the clutch pedal (sometimes accelerator too) the cruise control stops from working, if the sensor is old and isn't positioned correctly it can trigger a false positive information, and the cruise control detects it as you pressed the pedal and stops working.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks alot !!
por
No problem :)
por
Adicionar a sua resposta
Alex será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 99
