Ir para o conteúdo principal
O novo modelo da Apple para a linha 14 apresenta uma OLED de 6,7 polegadas, como aquela do Pro Max, mas vem com as mesmas funções que o iPhone 14, com uma configuração de câmera dupla e chip Bionic A15 com GPU de 5 núcleos.
20 Perguntas Visualizar todos
What might be the possible soln to this log below
Veja o conteúdo da imagem:
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I currently have this same issue. 0x400000 is for the wireless charging coil flex. My rear cameras and flash are not working either, do yours? I have tried replacing the wireless charging coil already and it did not fix this kernel panic.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Unfortunately yes I have the same problem , no flash and no back panel. I don't know what to do to make it work . I haven't found a solution yet . I tried to put an aftermarket rear panel on it , but it was probably the panel that was faulty . Did you try to fix it with a factory part ?
por
Yes I ordered a new rear camera and wireless coil to see if either part was faulty and causing the others not to work. I also tried 2 different back panels and none of the parts fixed the issue with panic. Im starting to think that its not the camera or the wireless charging flex and actually an issue with the logic board that has disabled those circuits. I have done multiple restores even with the new parts installed and that didn't fix it so Im out of ideas.
por
Adicionar a sua resposta
Ernő Németh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 83
