Ir para o conteúdo principal
The Sony DualSense Edge (CFI-ZCP1) wireless controller was released in January 2023. It features replaceable joystick modules and other upgrades from the DualSense.
Looking to find a replacement touchpad for the edge controller.
Looking to find a replacement touchpad for the edge controller. Anyone know where to find one?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Sure, you can find them here: https://www.aliexpress.us/item/325680525...
You only need to choose the correct version.
Good luck with the repair!
Esta resposta foi útil?
Pontuação 1
2 comentários:
I will check them out . I was replacing the shell on my edge controller and melted the original touch pad plastic. If I want to put back to normal I want to get the same OEM pad. Thank you
por
Hi! The plastic part can be found here: https://www.aliexpress.us/item/325680444...
It’s difficult (near impossible) to find the OEM part. Sony does have their own supplier. Those are copies.
por
Adicionar a sua resposta
morgancaleb21 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 82
