Some of my keyboard buttons are popping out of place
My W A S D buttons are getting out of their place
Esta é uma boa pergunta?
Hi!
Reading those comments, it looks like you’ve tried to put the keys back on, but they will come off all the time. I’m afraid that it’s for the best to replace this one. It will probably only get worse :(… sorry!
Unfortunately, HP decided to fuse the keyboard with the palm rest (top cover) for this model… it’s still possible to replace the keyboard and remove it from the palm rest (top cover), but it’s a pain in the as* to remove the keyboard from it and to put a new one in.
I recommend to replace the top cover with the keyboard all in one (this is factory standard OEM).
You can get the part from HP with the correct part number.
Esta resposta foi útil?
alright thaank you so much! I'm very grateful!
@alikohail my pleasure! Good luck with the repair and let us know how it goes!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 61
11 comentários
Have you ever taken them off before?
por Hampter
@hampter yes but not on purpose they keep popping out as i type
por Ali Kohail
i tried to fix it once by gluing them on
but it didnt quiet work
por Ali Kohail
@alikohail is it every time or just like occasionally?
por Hampter
I have this issue, with my E key on my MacBook Pro 13" Retina Early 2015. I've inspected both the keyboard slot, and the key. No visible damage. So I simply have had to put up with it. I've gotten used to it, barely noticing it now, and when it does get loose, I know how to quickly snap it back on.
por Moth
Exibir mais 6 comentários
