Ir para o conteúdo principal
Lap top didn't read second ram I try every thing update bios still
Lap top didn't read second ram i try every thing update bios still didn't work some time gets read and at most didn't also when i open task manger hdd is always 100% any help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Was the RAM recently installed? Or is it the one that came with the device?
I had a 2011 Asus computer that wouldn't start on me. I removed 1 of the RAM sticks, started it up, and it was fine! I put that stick back in, and nope, won't start.
I suggest that if you feel comfortable enough doing it, try removing the RAM and starting it, remove 1 stick at a time. This way you can hopefully find the problem stick, (if it is the RAM stick).
Esta resposta foi útil?
Pontuação 0
2 comentários:
I try the ram that came with it and other new ones same problem
por
Hmm, I’m not sure then. Sorry, that’s all I could think of
por
Adicionar a sua resposta
omar mohamed mohamed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 136
