Capture button isn't working for switch lite
Switch capture button isn't working
Esta é uma boa pergunta?
Hi Maria!
What is already tried? Can you press the button or not at all?
Assuming that the Switch is up to date and that you've tried all the resets, the best thing to do is to clean the board on the left and to replace the rubber for the "capture" key. You only need to replace the rubber if you can't click it in properly.
Otherwise, you need to replace the board (left side daughterboard).
This the part you need: https://www.amazon.com/Motherboard-Mater...
Guide: Nintendo Switch Lite Left Joystick Replacement (till step 27, after replacing the board continue to assemble the Switch again).
Good luck!!
Esta resposta foi útil?
All other buttons/joystick full work but capture button is only one not working. It is updated
Okay, if this is the case, then the board need a replacement. Button has a electronical defect…
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 35
