Issues with sim card not being registered
Hi ive replaced the lcd on my device but after the sim card is not being detected at all any suggestions i have two different sim boards ive tried and i get the same results
Esta é uma boa pergunta?
probably a problem with the sim board connector flex cable / charging port check the connector
i hope u can get it to work
Esta resposta foi útil?
Same happened to me, I factory reset the phone, it recognised the SIM for about 1 hour then it stopped working again.
It almost look like a software issue, does anyone has a fix please?
P.S: I solved mine, you literally have 2 slots on the sim slot back to back make sure you put it in SIM 1.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 51
