Charging not going over 22%
tried different cables but charging not going over 22% , wireless charging works. what might be the issue?
Esta é uma boa pergunta?
What is handy for diagnosing problems like this is an inline USB voltage/current monitor. They are inexpensive on Aliexpress.com
Is the same adapter used for the wireless charging? The first thing I would suspect is the voltage output of the adapter.
A discharged battery is typically about 2.7V. Fully charged is 4.2V. Obviously, in ordet to get to 4.2V the supplied voltage must be greater than 4.2V. USB is 5V for normal charging. If the supplied voltage is only say 3.0V, then it will only get to about 22%.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 106
