Ir para o conteúdo principal
The 2005 RL was also the first Honda vehicle to use the Advanced Compatibility Engineering (ACE) body structure, which has since proliferated throughout every newly introduced Honda and Acura vehicle design.
How do I rematch the smart key to the car?
The first problem was the battery drained and the car wouldn't start. The second is I changed the battery in the smartkey and all communication stopped. The green key on the cluster flashes and welcom driver no longer appears. When we try to rematch the key the message we get says no communication with ecu
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like you changed the battery in the FOB because it wasn't working. Now, with a new battery, it still isn't working.
Then you tried to repair the FOB, which you shouldn't have needed to do anyway, so it looks like the problem is in the ECU. I assume you don't have another FOB to try.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Placido Baca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 116
