Phone won't turn on but battery is fine
Once the phone turned off while running and then did not turn on again. And it is not charging when I plug it in.।What should I do? I think the motherboard of the phone is damaged
Esta é uma boa pergunta?
I'm not sure if this can help, but you can try doing a force reset by pressing the power and volume up button at the same time until there is a logo pop up on the phone. If that doesn't work, then I believe the motherboard might be broken. I found an ebay link that has a working 16 GB motherboard: https://www.ebay.com/itm/334225280740
A repair at a shop may cost around $150-300.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 5
