Maytag loses power during cycle
Model: MDB7749AWB1
Symptom: Maytag, loses power during it's cycle. After 20 - 30 seconds power comes back on and the Start/Resume light is flashing.
Troubleshooting:
Replaced Control Panel
Replaced Control Board
Replaced Control Board Thermistor
Cleared filter of debris
Checked continuity with tub Thermistor and multimeter
Checked continuity with Heating Element and multimeter
Ran Diagnostic pressing Heated Dry + Normal + Heated Dry + Normal with no apparent trouble detected for each interval
Control Panel was replaced due to no power, this fixed it for at least 1-2 years. Next it lost power again checked the Control Board Thermistor and found no continuity, replaced and restored power. Dishwasher began exhibiting symptom described and replaced the Control Board with no change in symptom.
Checked drain, ran diagnostic, tested heating element continuity and tub thermistor continuity. If there are any other suggestions I'm open. Thank you for your attention.
Esta é uma boa pergunta?
