Ir para o conteúdo principal
Impressora multifuncional tanque de tinta Wi-Fi Epson EcoTank L3150
Scaner dosnt work , it's stick.
When i pick to scan , they scaner makes a sound like it's being stuck ando don't make the copy.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
See for any paper jams etc, Head cleaning, ink charging, or ink drying is in progress. Check to see if the Pause light is flashing.
por
Adicionar um comentário
1 resposta
Solução escolhida
That is common problem for this type (l3150, 3110, 3210) this problem cause by:
  1. Improper scanner attached to its pin.
  2. Hard stuff/heavy stuff felt down on to the scanner.
  3. Dust accumulate on the scanner tract.
Solution:
  1. Check ribbon scanner cable, whether it is torn uuo or not.
  2. Dissemble the scanner and clean the track, while repositioning the scanner correctly (don't miss even half millimetre).
Hope this will answer your questions.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nahum Alejandro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 782
