Ir para o conteúdo principal
Whenever I turn on the laptop the screen flickers and shutdown
Whenever I turn on the laptop the screen flickers and then shut down and my laptop screen is alright and my power don't turn on without charger I need plug the charger to use it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It seems like a bad/dead battery, have you tried to keep the laptop plugged in for a while? If so, does your OS show that your battery is 100%
If the above is true, then you should look into replacing your battery, remember that dead batteries can do damage, so fix them asap!
Esta resposta foi útil?
Pontuação 0
2 comentários:
My laptop isn't turning on whenever I start my laptop the screen flickers and caps lock key blinks and then the laptop shutdown and the display is fine
por
@saudahmadb are you sure that its not a faulty battery with limited charge?, should probably replace it if it only powers on with a charger connected
por
Adicionar a sua resposta
Saud Ahmad B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 27
Duração total: 27
