Ir para o conteúdo principal
Joysticks keep Drifting *both left and right
Hi! I own a PS4 and recently during games my view screen has been moving around as if I'm moving the left joystick, and sometimes my character even walks on its own (as if I'm using the right joystick). I notice this happens more often when I have my headphones plugged in, so I figured it could be some mixing signals? Does anyone know how to fix this ?
Thank you!
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Laslus!
Drifting joysticks can be solved by replacing them. You probably need to open it up and replace them both.
This requires soldering…
Also check if the replacement joysticks will match your original ones first.
Esta resposta foi útil?
Pontuação 2
2 comentários:
hi pls for this controller can i use analog of ps4 or ps5 to replace them?
por
Hi! Not sure.. they probably do fit, but not sure about it..
por
My game console analog is drifting right and left
Pontuação 0
1 comentário:
Then they both need a replacement!
por
Adicionar a sua resposta
Laslus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 154
Ao todo: 961
