Fuel light not lighting on dash panel
No fuel warning on dash panel
Esta é uma boa pergunta?
Greetings David,
When you first turn the key during the initial power on light test does the light attempt to light at all?
Try these steps.
Report back the result and I can dig you up some further instructions. The Hondas from memory are usually designed to light up if less then 2 gallons of gas.
Hope this helps!!
Cheers
Monte
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 23
