Ir para o conteúdo principal
Guides and repair information for washing machines produced by Hotpoint, an appliance manufacturing company based in the US.
Display cannot be read, all the pixels are lit
Hello Together,
I have a problem, that after power on, the display shows no text, but all the pixels are being lit. Already dismantled display panel, checked the cables, also the flat cable between the control panel and display module, if any contact problems caused the error, but no results.
Interesting is, that if you know, which button how many times has to be pushed, to start a program, then the cycle starts without problems, so only the display does not show that, only all pixels are lit up.
Sometimes when machine is powered on, everything is fine, you can select the programs, all texts are visible and starts the washing cycle, but after some time, the same error happens again.
Thaks for the answers!
Type is: hotpoint Ariston FDD 10761 XR EU..
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like there may be a malfunction with the display module or its connection to the control panel. Since you've already checked the cables and connections, it could be an internal issue with the display itself. Given that the washing cycle starts correctly when initiated manually, it suggests that the control panel and other components are functioning properly. You may need to consider replacing the display module or seeking assistance from a technician familiar with hotpoint Ariston FDD 10761 XR EU models.
Esta resposta foi útil?
Pontuação 0
1 comentário:
@rapidappli29121 careful with your Answers. iRobot is pretty ruthless about marking your answers as spam if it discovers too many links to your own profile or always to the same site. Self promotion is considered spam and iRobot takes care of that as well. iFixit has a zero tolerance policy.
You can link to whatever you like to in your About page but never in Answers. This is what keep us all focused on what matters and that is helping others. Yes, really, that is what this site is all about. Just a whole bunch of GOODY TWO-SHOES that believe in empowering anyone to fix their own devices.
Repair is War on Entropy!
por
Adicionar a sua resposta
István Nagy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 181
