Ir para o conteúdo principal
Laptop released in 2019 by Acer, Acer Nitro 5 includes 8 GB RAM (expandable up to 32 GB with the proper hardware) and red backlit keyboard.
16 Perguntas Visualizar todos
How to make FA100-1TB work?
I recently bought an FA100-1TB SSD thing for my laptop, but after some messing around I don't think it works or I'm doing something wrong. I tried both PCie ports, along with the original SSD(Or I think that's what it is) that came with the laptop(It doesn't work without it) and I don't see the 1TB anywhere :(, Please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Assuming you plugged it in properly, Windows should see it. You may have to format it, but if it is not showing up as a drive, you can't. Look in your Device Manager to see if it shows up under disk drives. You should see 2 SSDs listed. If not, use your warranty.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you :)
por
Adicionar a sua resposta
Jose L. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 76
