Loose Joy-con’s
Both of my Joy-cons (left and right) are loose and come out of the console very easy, how do i fix it?
Esta é uma boa pergunta?
I ran into something that sounds similar on my granddaughter's Switch; while I wouldn't have described it as "loose", one of the Joy-Cons did slide off the Switch console very easily and often at inopportune times.
The fix for her Switch was to replace the little locking mechanism, called the buckle lock. It's basically a piece of plastic with a spring that snaps the Joy-Con onto the rail and keeps it in place. The problem is, the buckle lock is plastic and the rail it snaps into is metal, so it's only a matter of time before the plastic wears down far enough that it won't keep the Joy-Con on the rail any longer.
The fix is fairly straight-forward; you just replace those plastic buckle locks with a pair of metal ones that you can get right here on iFixit.
Nintendo Switch Joy-Con Replacement Metal Buckle Locks
Being made of metal, they won't wear out like the originals. Oh, and you'll be wanting a guide to show you how to put those in, which iFixit also has for you.
Joy-Con Buckle Lock Replacement - iFixit Repair Guide
The only gotcha you'll want to be aware of is that the buckle locks are specific to each side Joy-Con; there's a right hand one and a left hand one. If, like me, you don't notice that fact and put them in the wrong side, they'll go in okay but won't keep the Joy-Con in place. Then you get to go do the whole operation again, only with the correct buckle lock this time. So don't be me, okay? :D
Good luck, and let us know how it goes!
Esta resposta foi útil?
@dadibrokeit Jerry, thanks for sharing! I was looking for those metal buckle locks!
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 55
Duração total: 140
1 comentário
That depends on what you mean by "loose". Can you elaborate on that a bit? Do they wobble around in the rails? Do they pop out as soon as you press on them? We need to know the specific problem to be able to help fix it
por darth mango
