MacBook Pro can't turn on, Magsafe light still lights up
Hi there! A few days ago when I opened my Macbook Pro mid 2012 Retina 15", everything worked fine, but only after a few hours leaving it charging, it suddenly became a brick. NVRAM or PRAM, SMC reset doesn't work, unplugging the battery doesn't work as well, I've got no response from the Macbook at all. The only thing that still "works" is the light on the Magsafe charger
Opening up the under case, after a bit of inspection I've noticed when plugged in, these resistors warmed up, with the one marked red became blazing hot, even capable of melting plastic bags.
Is there any way I can fix this, or this motherboard is now dead? And if so, what could be the cause for this? Thanks in advance!
Esta é uma boa pergunta?
