Display Glue Strips Not Holding in Lower Right Corner
It was a fun project:
I converted a 27" iMac into a 5K display using a special display driver board from AliExpress. I did a good job removing and cleaning the old glue strips before applying the new iFixit glue strips.
When setting the display back on the case I had to make a couple of lateral position adjustments and while doing so lifted the display from the bottom glue strip where it had been very briefly attached. Not sure if that's the source of my problem...
What I'm seeing is that the glue is holding well except for that lower right corner, where the display seems to be slightly lifting away from the case, for maybe about 4-6" from that corner.
I keep pushing it back in place and it seems to hold briefly, but eventually curls slightly away in that corner. My concern is that the problem could grow and the display actually fall off the case. So...
My question: is there some way I can reglue/fix that lower right corner without removing everything and starting over.
Other than this problem, my project turned out great, and it's 5K display works like a charm with my Mac.
Esta é uma boa pergunta?
