Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Perguntas Visualizar todos
Lower screen displays for a while, but then the image becomes glitched
I have a DS Lite where the bottom screen works for a while, but then it becomes glitched out and discolored. Touchscreen works fine. Sign of a bad connection or a bad screen as a whole?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi! Looks like your lower screen need to be replaced. Do you have a video where you can show how the glitch look like?
Esta resposta foi útil?
Pontuação 1
It seems you're experiencing an issue with your Nintendo DS Lite's lower screen. Let's troubleshoot this glitchy display! While I'm not a certified technician, I can offer some insights based on common problems:
1. **Bad Connection**:
- A **loose or faulty connection** between the screen and the motherboard could cause display issues.
- Check if the **ribbon cable** connecting the lower screen is securely attached. Ensure it's in a straight line and properly seated.
- If you've recently replaced any parts, consider trying the **old bottom screen** to see if the issue persists.
2. **Faulty LCD Screen**:
- The **discolored and glitched display** might indicate a problem with the **LCD screen** itself.
- Sometimes, a **defective new screen** can cause issues. If you have the old screen, test it to rule out this possibility.
- If the problem persists, consider replacing the **bottom LCD screen**.
Remember that these are general suggestions, and for a precise diagnosis, it's best to consult a professional technician or refer to official repair guides.
Pontuação 0
Adicionar a sua resposta
Cych será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 20
