System unit won’t work when cpu is fixed
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
@kinibernard - And... What system, why did you take the CPU out????
You really need to give us a story on what happened as your question doesn't make much sense.
por
It generally isn't good to fix a cpu on your own unless you have the right equipment, they are very fragile. I'm sorry to say but if you did it yourself then your "repair" probably ended up breaking it for good. But what did you do to the cpu and what was the original problem?
por
من هم مشکل شما را دارم وقتی cpu را در جای خودش وصل میکنم فن ها کار میکنند ولی کامپیوتر روشن نمیشود.
وقتی CPU را جدا میکنم مادربرد روشن میشود ولی صفحه سیاه میشه
por
@sajjadskan79313 what CPU? What motherboard? Why are you changing the CPU? What have you tried? We need more history here. Right now, this sounds like a bad CPU.
@sajjadskan79313 چه سی پی یو؟ چه مادربردی؟ چرا سی پی یو رو عوض میکنی؟ چه چیزی را امتحان کرده اید؟ ما در اینجا به تاریخ بیشتری نیاز داریم. در حال حاضر، این مانند یک CPU بد به نظر می رسد.
por
Adicionar um comentário
