Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
How to reconnect left hinge to the rest of the hinge?
The display from my Mac has a broken hinge. The left part of the hinge is disconnected from the rest of the hinge. How would I reconnect it? I don't care about the cosmetic appearance of the hinge.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It's hard to tell from the picture how exactly the hinge has broken or if it would be repairable. If the screws have come loose but all of the actual hardware is still in tact then you make be able to use it. Otherwise, you might have to remove the display, remove the display hinge, and fully replace that particular broken hinge (which I believe also includes the display cable). Here's a guide for how to do that on the 13-inch model, which I think is a similar procedure for the 15-inch. Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peap Wu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 103
