Mengapa hpnya tidak bisa dicas Why can't the cellphone charge?
Translation Indonesian - English
Esta é uma boa pergunta?
@zaidsadan you are not giving us enough information. You need to consider to let us know if anything happened to your phone or if it just stopped charging. Let us know what you have checked and what your have already tried to fix this.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the charging cable connectors are not bend etc. After that, check the charging port. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, you could get a ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage check the flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone also has a separate charging board that could be faulty, consider replacing that.
Since iFixit does not yet have the guides for this, use something like this video It'll show you how to replace the battery. For the charging board follow this video Combining those videos will show you how to do both
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new It is absolutely okay to write these guides in your native language. iFixit has a great team of translators.The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@zaidsadan Anda tidak memberi kami informasi yang cukup. Anda perlu mempertimbangkan untuk memberi tahu kami jika terjadi sesuatu pada ponsel Anda atau jika pengisian dayanya berhenti. Beri tahu kami apa yang telah Anda periksa dan apa yang sudah Anda coba untuk memperbaikinya.
Pertama, Anda ingin memeriksa catu daya Anda. Pastikan tegangannya sesuai. Periksa untuk memastikan konektor kabel pengisi daya tidak bengkok dll. Setelah itu, periksa port pengisi daya. Pastikan tidak ada korosi, serpihan, dll. yang menghalangi kerjanya. Bersihkan dari kotoran dll, gunakan beberapa hembusan udara untuk membersihkannya. Jika tidak ada yang berhasil, Anda bisa mendapatkan ammeter dan melihat apakah ponsel Anda mengambil arus listrik dari pengisi daya.
Anda mungkin juga harus mempertimbangkan untuk mengganti baterai. Baterai yang habis tidak dapat diisi lagi. Ukur voltase pada konektor baterai Anda dengan pengisi daya terpasang. Anda akan mendapatkan tegangan sekitar 4,2V. Jika Anda tidak mendapatkan voltase ini, periksa kabel fleksibel yang berasal dari papan pengisi daya. Pastikan terpasang dengan benar dan tidak ada robekan atau kerusakan lainnya. Ponsel Anda juga memiliki papan pengisi daya terpisah yang mungkin rusak, pertimbangkan untuk menggantinya.
Karena iFixit belum memiliki panduan untuk ini, gunakan sesuatu seperti video ini Ini akan menunjukkan cara mengganti baterai. Untuk papan pengisian daya, ikuti video ini Menggabungkan video tersebut akan menunjukkan cara melakukan keduanya
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah Anda selesai melakukannya, ambil gambar itu dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki masalah yang sama seperti Anda. Sangat mudah dan menyenangkan untuk membuat panduan ini. https://ifixit.com/Guide/new Tidak masalah jika Anda menulis panduan ini dalam bahasa ibu Anda. iFixit memiliki tim penerjemah yang hebat. Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang Melawan Entropi!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 29
