Ir para o conteúdo principal
A quarta geração do Volkswagen Jetta, também chamado de MK4 ou Bora, é o sedã familiar da Volkswagen.
Do I need a special scan tool after replacing my ECU/ECM
I was told after replacing the ECU you need to take it to the dealer to reprogram the new one. is this true?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The simple answer is yes, an ECU on this vehicle is not plug and play and will need both a certain level of Scanner ( Out of most peoples budgets) and program. That being said how did you determine the ECU / ECM was bad. What steps were taken to prove the fault that led you to replace the ECU/ECM if you did not take it to the dealership.
You might locate and independent repair shop that has the required tools and knowledge to do the programming for a better price then the dealer.
Just asking was this a shot in the dark kinda thing?
Cheers,
Monte
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 303
