Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
M1 MacBook Air speakers have distortion/rattling
My M1 MacBook Air speakers have strong distortion/rattling, most noticeable when listening to piano music. The distortion is present even at 25% volume.
I tried buying a used set of speakers on eBay, but they had the exact same distortion. My best guess is that the used speakers I bought on eBay were also damaged, but is it possible that my audio board is the problem? There is no distortion when using headphones, so it seems unlikely that the audio board is at fault, but I want to be sure that it's good before I buy another set of speakers.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
yes it sound like it is the speakers but I would first check that the speakers where properly installed in the first place as it can be easy to not replace them quite right.
Esta resposta foi útil?
Pontuação 0
1 comentário:
My speakers were original, installed from the factory by Apple. They worked great for a while, but then they started having strong distortion.
Then I installed replacement speakers by myself, and they had the exact same distortion as the original speakers. I installed them with double-sided tape that was exactly the same width as Apple's adhesive, applied in exactly the same spot, and the speakers were perfectly centered in the cutout where they belong.
por
Adicionar a sua resposta
Daniel Korzhenevich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 134
