How can I replace a broken USB port?
The USB port on my controller works intermittently, is there a way to solder a cable directly on or replace the port?
Esta é uma boa pergunta?
If you follow this guide you should be able to disassemble the controller and get to the card where the port is located. Either solder a new one on yourself or use a repair service provider near you if you feel uncomfortable soldering on your own controller.
Xbox Series X|S Wireless Controller (Model 1914) Full Disassembly
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 235
