Ir para o conteúdo principal
Replacing the Audio Assembly
I have a customers 4th gen nano, there is no sound coming from the audio assembly, so naturally, i would replace it... but in the 4th gen nano it is soldered onto the board, i just want to know if anyone has ever successfully soldered a new one on, or fixed the old one, ie..replacing the pins inside it or whatnot. any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I think you will need an all-new board as the soldering is most likely surface mounted; making it incredibly difficult to solder.
Esta resposta foi útil?
Pontuação 4
3 comentários:
i received replacement parts from china, they have the setup done, but yes i am afraid to resolder or reglue... until i hear someone has done so otherwise
por
this is true, soldering a headphone jack on one of these is work for robots.
por
my ipod got the problem too,
i am looking for the parts in china,
just wanna know did u did it eventually??
por
Adicionar a sua resposta
Ptr702 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 2,490
