Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
20 Perguntas Visualizar todos
I Swapped the Trigger and Bumper Ribbon Cables
I swapped the Trigger and Bumper Ribbon Cables with new ones and now the controller doesn't power on. If I disconnect one of the t&b cables (L1/L2) and leave the other one plugged in (R1/R2) the controller powers on and R2 and R1 work. I'm confused as to why this happens. Any help?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
What if you disconnect the R1 & R2 cable? But leave the other one connected, does it still power on?
por
No it does not
por
Any solution??
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Have you doublechecked that the triggers match up with the points on the controller responsible for registering input? If not do that.
There should also be a spring in the buttons. Is this connected correctly?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Benji Customs será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 74
