What phone is this
it said SE under general, but is different from videos of 6,SE, 7??
Esta é uma boa pergunta?
There are three iPhones with the designation "SE"; the original, the 2020 model and the 2022 model. The "Axxxx" model information will tell you which one you have. Here's how to find the number you want.
You can identify the second generation of the iPhone SE (2020) by finding one of the model numbers either on the inner edge of the SIM card tray or within the phone's Settings app.
You can find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The SE 1st generation is based on the 5S chassis and the model number will be one of: A1662, A1723, A1724.
The SE 2020 is based on the iPhone 8 chassis and will be one of: A2275, A2296, A2298.
The SE 2022 is also based on the iPhone 8 and has model numbers: A2595, A2782, A2784, A2785, A2783.
Esta resposta foi útil?
is there a reason why the last group of SE2022 numbers are not in sequence?
@johnkeatin77492 According to everymac.com, here are the differences.
The US/Canada/Mexico/Saudi Arabia (A2595), Japan (A2782), and Global (A2783) iPhone SE 3 models support dual SIMs -- one physical Nano SIM and one digital eSIM -- but the model sold in mainland China (A2785) only supports a single Nano SIM.
So the A2595 is the US model, and the A278X models are for the rest of the world. They don't list the A2784 model for some reason.
@johnkeatin77492 So, which one did yours end up being?
it's dissembled at the moment, so I'm not certain.
but i know i ordered the wrong battery.
didn't realize there were varieties of SE
@johnkeatin77492 Ah, you can always check in the SIM card slot; it's engraved there.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 62
3 comentários
thank you that is helpful
por john keating
thanks again for the help
por john keating
thanks again Jerry. I got things back together and I'll dig deeper to ID it.
por john keating
