MacBook Pro slow after battery replacement. CPU throttling?
Hi everyone, I've recently replaced my Mac battery (for info the model is Macbook Pro 15'' Retina Mid 2014 A1398 E2881 and this is the battery https://www.ebay.it/itm/166497175632)
I carefully replaced it and tried to use the computer and all seemed to be working just fine. So I started to calibrate the battery in this way: charge it to 100%, unplug the charger and use the computer until it shuts down, wait 3-5 hours leaving it off and lastly recharge to 100%.
After this process I started to notice that everything works slower than before, so I checked the task manager but nothing appeared wrong, same with temperature sensors etc.
What I tried to do was:
-run Clean my mac
-SMC and PRAM reset
-start the computer in safe mode
-start the computer with the diagnostic (pressing D), but no error showed up
- enter mac OS recovery and run disk repair
-run Onyx
Then i ran some benchmark:
-with black magic all fine
-geekbench 4.4.4 showed really low scores, like 1/3 or less that it should be
-etreCheckPro recognized that the computer is slow and that the CPU and RAM usage is too high based on the programs running (nothing but this one)
Some told me that it could all be due to the battery incompatibility... but the specs are right and I double-checked the codes of the original and the substitute and they coincide.
Furthermore I also have Windows10 installed on an external SSD running with BootCamp, it's also slower than before.
Does anyone have any idea of what more I could do?
Fans and temperature sensors appear to have no problem
Esta é uma boa pergunta?
