Ir para o conteúdo principal
Stainless steel convection oven. Model:BOV900BSSUSC
Error code E01 (Thermistor issue, maybe). Any self fixes for this?
Breville warranty site says 'E01' is a non-resettable error and the oven needs to be sent to their repair service. Trying to avoid that, web searches point to this being a potential temperature sensor malfunction. Any chance this is something that can be fixed on my own? TIA
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
The E1 error seems to be pretty standard across air fryers and usually signifies thermistor failure as you said. You can test the functioning of the probe using a multimeter. If it is faulty, it will likely give you sudden inconsistent jumps in resistance as you heat it.
Replacing the NTC thermistor probe will likely solve your error. Here is a guide for a similar Xiaomi air fryer I recently translated from Spanish. If you have any doubts, don't hesitate to ask.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you, David! I will give that a shot and report back.
por
@boocoo I admit the guide is originally written in quite a chaotic manner that I had to partly translate over, so I apologize for any potential confusion that may arise.
I wish you the best of luck.
por
Adicionar a sua resposta
boocoo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 16
Últimos 30 dias: 46
Ao todo: 835
