Ir para o conteúdo principal
Announced March 10, 2021 Released April 26, 2021 Android 11, up-gradable to Android 12, ROG UI
Does Fingerprint sensor works after screen panel replacement?
I Need my screen to be changed due to broken glass, i need to know if my fingerprint sensor will function as intendes after a screen replacement since i really need fingerprint scanner.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey, @rex50018
I've done a few screen replacements on ROG 4s and 5s, and I can say for certain your fingerprint scanner is still going to work. If you properly connect all the cables and put everything where it belongs, it'll function the same as before, or maybe even better. Just make sure there's no dust or debris covering it before you put the device back together. Good Luck.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Rex será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 140
