Ir para o conteúdo principal
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
Which screens will work with this MacBook?
I'm looking for a replacement screen for this MacBook Pro 2019 with Touch Bar. Will a screen from a non touch bar MacBook work with this? Are the screens the same?
I understand that a 2018 or 2019 will work.
Thanks for the help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Here’s the needed part MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and the guide to put it in MacBook Pro 13" Touch Bar 2019 Screen Replacement there are differences between the TB an Fn model assemblies as such I wouldn’t tempt swapping them.
Imagem de Replace a display compatible with a Mid 2018 to Mid 2019 model A1989 or A2159 MacBook Pro 13" with laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, and Clutch Hinges.
Produto
$479.99
Esta resposta foi útil?
Pontuação 0
@jlaffin
A1708(Fn-Key Macbook) screen will work with your model, however it will glitch during boot, there will be no truetone and no keyboard backlight on butterfly models (yours).
Also on any OS newer than Catalina it will have dim backlight, approx 50% lower than normal.
if you get screen for free or really cheap, it worth trying to install A1708 and patch EDID(this will fix Brightness issue but not ALS / TT / Keyboard BL ):
https://github.com/waydabber/BetterDispl...
Pontuação 0
Adicionar a sua resposta
Julian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 119
