Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
SSD Upgrade "Kit" without regular tools?
I only need the proprietary tools and parts in the Mac Mini Hard Drive Kit. The screwdriver box set is something that I already own and it would be redundant to buy it again (this also wouldn't be the iFixIt way).
Can I buy all these parts separately? iFixIt, why don't you have a kit like this for seasoned DIYers?
Imagem de All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.
Produto
Mac mini Dual Drive Kit
$26.99
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
This is the volunteer DIY board - I suggest you contact iFixit direct.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
You can do this yourself. Prying out the logic board you could figure out without the supplied tool. But you will need the SATA connector.
Pontuação 0
Adicionar a sua resposta
Joel Gillman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 4,979
