Ir para o conteúdo principal
Guides and repair information for the MTX Terminator TNA251, a 250-Watt car amplifier.
Blowing fuses when I turn on
How can I fix my self anyone know how to fix a amp
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If there's an internal shorting problem with the amp, then there's not much you can do yourself - the amp will need to be professionally repaired. Double-check all your power wiring to the amp. Disconnect everything from the amp except for power, ground, and remote turn-on. If the amp doesn't blow a fuse, then there might be a problem with the speakers or speaker wiring that is causing a short. Track down any wiring shorts or damaged equipment attached to the amp. The first step in diagnosing a problem amp is to fix everything connected to it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
David Gagne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 84
