MacBook does not enter sleep on low battery after battery replacement
Hello,
After changing my MacBook Pro Retina batery using iFixit battery I notice that my MB does sleep if not in use but when working with it It drain all the battery and does not sleep on low battery it just go down.
It is doing this since the replacement.
I already try to reset SMC with no success.
I already see that other buyers did get the same issue with the replacement battery, so is there any fix for this issue ?
Thanks a lot
Update (02/29/24)
Update:
% pmset -g assertions
2024-02-29 18:01:58 -0100
Assertion status system-wide:
BackgroundTask 0
ApplePushServiceTask 0
UserIsActive 1
PreventUserIdleDisplaySleep 0
PreventSystemSleep 0
ExternalMedia 0
PreventUserIdleSystemSleep 0
NetworkClientActive 0
Update (03/04/24)
Hello Dan, Thanks for your reply , I already use coconutBattery for years.
Here is the information
When I have time I will disconnect the battery for full drain residual current.
Thanks
Esta é uma boa pergunta?
@credesign - I would prefer you did the hard SMC reset I described in my answer
por Dan
