Ir para o conteúdo principal
Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
Possible to replace WiFi without replacing entire motherboard?
WiFi seems to be dying on my 2021 16" Apple M1 Max laptop. Is this something that can be repaired, or would the entire logic board need to be replaced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
hi, did you try updating the drivers of the wireless card?
Esta resposta foi útil?
Pontuação 0
It’s possible your issue is within the WiFI network side not within the systems hardware. I would go the the App Store and download one of the WiFI monitoring apps as they can help you figure out what’s happening. I use WiFI Explorer but there are a few others that work just as well.
Pontuação 0
Adicionar a sua resposta
Jeff Diamond será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 17
Ao todo: 232
