Why my Scotty speedometer not working
Esta é uma boa pergunta?
Please check the meterconsole cable is connected well or broken. Its is cable that attached with front tyre and speedometer. If did you notice the cable is not working then replace with new meter cansole cable. ( Also check that your Km - reading meter is working or not. If the both meter are not responding then you just confirm that it was problem of the meter console cable. If only the speedometer was complaint then it was the only problem of meter console system)
Esta resposta foi útil?
My aerox not starting in morning.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 838
