Ir para o conteúdo principal
Repair guides and disassembly information for the 14-inch MacBook Pro released in November of 2023, featuring M3 Pro and M3 Max SoCs.
Can the SSD be replaced
Can the SSD be replaced or increased in size?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi Mkozy,
Unfortunately, Apple has started soldering down their SSD's in an attempt to prevent user upgrades.
This means that the only way to increase your available storage space is to buy a new one.
Luckily there is a work around. You can connect external SSD drives through your Mac's USB-C ports which will increase its storage capacity but you will have to take them with you whenever you want to use the files stored on those drives.
I'm Sorry this fix isn't really ideal.
Esta resposta foi útil?
Pontuação 2
3 comentários:
When did they start doing that? I know some chromebooks do that with RAM and some of the drives that are in them? But Apple? I imagine they are trying to take the upgrade/repair right away from the owner which is nothing new. Do you know what models they started to do that with? What year?
por
@anthonying45356 Apple Started to solder down their SSD's in 2016 as well as the ram back in 2012
por
Granted, you can in theory upgrade the SSD. The caveat to this being that you would likely need to have micro-soldering experience, and an SSD from a donor motherboard.
por
Adicionar a sua resposta
mkozy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 125
Ao todo: 5,850
