Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
Why wont my switch turn on after water damage and I tried fixing it
Nintendo switch fan comes on when I connect the battery to the motherboard but it doesn't show anything on the screen and I tried it with a dock and nothing happened.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If your Switch is refusing to boot due to corrosion, then I believe that the motherboard is broken (along with some other components within the Switch). Sure the fan may come on, but that doesn't mean that some other component of the motherboard is still broken. So I would suggest a motherboard replacement, a guide on which can be found here (unless you can clean it somehow, which I talk about below): Nintendo Switch Motherboard Replacement
Other components of the Nintendo Switch may have also been damaged, such as the display or some other daughterboards (e.g. the MicroSD card reader), so I would recommend checking them for any corrosion, which can be cleaned up using this guide: How to Correctly clean corrosion from a MacBook Pro logic board. (I know it is for a MacBook and not a switch, but the processes are basically the same for the Switch)
If you are unable to clean up the corrosion, you can simply purchase replacement parts here: Nintendo Game Console Parts
Do note that this sort of repair may be rather costly and take a lot of time, so if you do wish to carry out this I do wish you the best of luck with it.
Imagem de MacBook Pro
Guia
Nível de dificuldade:
Moderado
2 hours
Imagem de Nintendo Switch Motherboard
Guia
Moderado
1 - 2 hours
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Julian Valentine será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 181
