Ir para o conteúdo principal
Repair guides and documentation for the Google Pixel 5 smartphone. Released October 15th, 2020. Model Number: GD1YQ, GTT9Q
Screen is black on google pixel 5
I replaced the battery on my Google Pixel 5 and it's screen stays black when i try to boot it. When I push the power button, it vibrates, but nothing else happens. Any idea as to why it's not turning on? I did everything according to the instructions I was given by a Ifixit.com. Except I messed up the pull strips on the batter and may have punctured the black lining underneath it but it wasn't too bad. When i was prying it open i preyed a bit to much to the top so i remove the plastic bit on the bottom of the screen. I ended up adding adhesive to stick it together but it didnt make a crunch sound when i pushed down the screen.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
So basically I think this might be a display issue. You said you fractured the cable that shows the display and have probably damaged it so much that you're going to need to get a new display and install it.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yeah i double checked the cable i think its fine. I have edited it a bit
por
Adicionar a sua resposta
Jerry26958 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 25
Ao todo: 340
