Ir para o conteúdo principal
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
20 Perguntas Visualizar todos
WD Black P10 Game Drive 2.5 HDD Won’t connect to my x-box one
Won’t connect to my xbox one. I have tried restarting xbox, updating and messing around with how it was plugged in. This holds most of my xbox one games and I now cannot play them. The white light is on indicating the WD Black is turned on, so I believe this might be an xbox one problem? Any help would be appreciated.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Sorry, 2.5 HDD
por
Adicionar um comentário
1 resposta
Solução escolhida
Format and test it on a PC, see if the HDD still works as a HDD.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I have tried plugging it into my Acer computer, does that work? It would not show up in device’s or drives. I could also try my dad’s MacBook, if that is better?
por
@billy63596 If it doesn't work on the PC like not seen in disk management, the drive is broken.
por
@tomchai
Thank you so much!
I will try my dad’s computer but if the reason is it is likely broken I won’t try that hard. I have contacted the developers support so I will see if they can help recover the data.
Thanks again!
por
Adicionar a sua resposta
Billy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 166
