Ir para o conteúdo principal
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
20 Perguntas Visualizar todos
Why won't any of my games work
I just bought a 3ds from Japan, it has been region unlocked but none of the games I have work in it. the pins aren't dirty or anything, but when I load a game it just says 'DS card can't be recognised. Please end the game and start again' or the screen just goes completely black and I have to turn it off and on again.
Ive tried googling but I can't find anything really related to this and I not sure what to do
does anyone know any way to fix this or have I just lost a load of money, I could send it back and get a refund but id still be losing money cause of the import tax :'(
can anyone help?
Update (02/20/24)
@rebtech it comes up with this
Esta é uma boa pergunta?
Pontuação 1
53 comentários
Booted from CTRNAND
Are you missing your sd card?
por
@rebtech I don’t know anything about this sorta stuff, I bought it like this and it has no sd card or anything
I have ordered a as card for it though
por
Oh yeah, that's not good. You need the sd card. Booting Luma from CTRNAND is only for emergency purposes in case your sd card dies or the like. Under normal circumstances Luma runs from the sd card. Because you don't have the sd card you are missing the Luma and the god mode 9 files. Not to mention you have no place to install title updates or seeds. I'm guessing this is your issue. You got sold an "incomplete" hacked 3ds, incomplete because the seller with held the sd card. :(
por
@rebtech am I not able to put the same files on a new sd card or would it not work?
por
Yes that will work. Just follow the hacking guide. From this point:
https://3ds.hacks.guide/restoring-updati...
Then afterwards do this for god mode9:
https://3ds.hacks.guide/godmode9-usage
Don't use sd cards larger than 128gb, make sure to format it to fat32. You'll need to use a different tool to format sd cards larger than 32gb windows wont do it natively.
por
Exibir mais 48 comentários
Adicionar um comentário
1 resposta
Solução escolhida
The only way games could be region unlocked is if it's been jailbroken. The question is which style of jailbreak was used and how long ago was it done. This will help determine what to check and how to proceed. Figure this out first.
With the 3ds off press and hold select, then press power. What happens?
Have a read here.
Particularly
https://3ds.hacks.guide/checking-for-cfw
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Acacia Scurr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 446
