Ir para o conteúdo principal
Repair guides and service information for Kenmore Dishwashers
19 Perguntas Visualizar todos
Kenmore 665.13732K600 Middle Spray Arm not turning
Dishwasher seems to run fine, but dishes aren't getting clean, soap is not completely removed from dispenser.
Action cam inside dishwasher shows middle spray arm is not turning.
Disassembled and cleaned out filters in lower part of dishwasher. No change.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Replaced circulation pump motor: No change
Finally noticed there didn't seem to be enough water in dishwasher.
Action cam confirms anemic flow during fill cycle.
But flow from inlet hose seemed fine.
Replaced fill valve. During replacement noticed teflon tape from installation was blocking inlet. I don't think the valve was bad but I left it in anyway.
Dishwasher now fills with a lot more water and middle spray arm turns as it should.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alan Nishioka será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 73
