Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
“5” Key is not working.
Hey guys!
So, the 5 key on my Mac randomly stopped working. I know this key is probably not as significant as the space bar, for example, but I still would like to fix it.
Here’s what I know: the key does nothing when I press it, and it will randomly type the 5 on its own. For example if I turn on Spotlight, it will type 5 many, many times on its own. Yet, when I hit the 5 key on the keyboard, it does nothing.
I have tried the basic steps, like reseating the ribbon cable, resetting NVRAM and SMC, rebooting the Mac and so on. Do you have any suggestions before I simply replace the keyboard?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @jadonlyon
Sounds like the ribbon cable, or connector is bad.
I can say for sure. it is not fun when that happens.
I sent mine to rossmann repair group to be inspected, They replaced the connector.
I find it likely you have the same issue.
Esta resposta foi útil?
Pontuação 1
3 comentários:
@beanman56 - Unfortunately I am not in a position to send my Mac in for repair, but now I have better idea on where to check. Thanks for the help!
por
@jadonlyon - I would have a good repair shop test with a new keyboard.
So you're not out $20 if it's something else.
por
@beanman56 - Sounds good, thanks!
por
Adicionar a sua resposta
Jadon Lyon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 160
