Fingerprint scanner not working after Battery replacement
Hello all!
As the title suggests, I replaced my Note 20 Ultra 5G's battery, however the fingerprint scanner stopped working.
It says to clean off the screen and make sure it's dry, and try again. Then if I try again, it kinda works, I have to press quite hard to even get 10% registered, and the the on screen scanner bugs out and doesn't register my finger anymore.
However, when I check the sensor by dialing *#0*#
, and do a normal test on my fingerprint scanner, everything says "PASS".
I'm at a loss, and would live some assistance and help!
Thanks in advance!
--EDIT--
I should mention that everything else on the phone works as expected, but the new battery drains faster than the old worn battery.
Esta é uma boa pergunta?
