Ir para o conteúdo principal
Problem with the 9.6 volt B&D Dustbuster battery?
Hello from Newmarket, On.
Is there any way to re-charge the batteries? The battery charge lasts about 20 seconds. A new B&D Dustbuster costs $95. and the batteries alone from Amazons costs $55.
Is it time to say good-bye to the Dustbuster.
canadadave
Thanks for listening. :))
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@canadadave trained at your fine Hospital decades ago :-)
This actually sounds like a bad battery. Could be issues with the battery control board or the cells itself. How comfortable are you taking it apart and rebuilding it? No, it is not as dangerous as it sound. It is not like any explosive ordnance disposal but needs common sense :-)
We would need some good pictures of the actual battery to see how to approach this. Hardest part is always cracking the case :-)
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
David será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 95
